jsawyer77
#1 Posted : Wednesday, May 19, 2021 1:37:30 PM(UTC)
jsawyer77
We have built a new vmix systme and now to get video to play I have to reset the imputs 2 or three times before it will display in vmix.
we have updated the duo software and made sure we have the latest firmware. the old system that also had the same duo cards in it doe3s not have this issue. Is there a setting or some option I need to choose so that the software resets all the inputs on load?
xaver
#2 Posted : Wednesday, May 19, 2021 4:51:01 PM(UTC)
xaver
Hi
we also had problems with the Decklink duo
every day, we must reset the inputs
with Decklink 10.8.3 it works much better (most time 3 to 5 days) without reset
fabfab10
#3 Posted : Wednesday, May 19, 2021 11:06:33 PM(UTC)
fabfab10
Italy
There was a significative change from BMD drivers 11.4.1 and following.
Even for some others environment is adviced to use this version in place of newer ones for Decklink Duo 2 and Quad 2.
For a correct installation (either upgrading or downgrading) i suggest to uninstall the package, shut down the system (i mean cold start not reboot), then install new drivers, again cold start.
At this point it should upgrade the firmware on the board.
Then another cold start and do the BNC setup for your needs.
jsawyer77
#4 Posted : Friday, May 21, 2021 1:26:56 AM(UTC)
jsawyer77
Ok I rolled the drivers back and still the same issue. To night I am going to try to load an older version of windows 10 to see if this problem goes away. With the old system I can unplug the bnc connector in and out of any of the interfaces on the card and the video starts. this one I have to right click and reset. Some times 4 or 6 times before I see video.
TIA
Josh
Joeboe
#5 Posted : Friday, May 21, 2021 1:43:48 AM(UTC)
Joeboe
I never had luck with any of my BM cards....I have a Duo, and another model, but they only show 1 instance of t cards....these cards have 2 inputs, but only one shows up, and sometimes I get the error message 'No Device Found', even though I see them in Device Manager...I tried everything I was told on line, in many forums, and found that many persons get issues with BM cards especially with windows 10 machines...as everytime an update is done, it messes up drivers from other apps....
fabfab10
#6 Posted : Friday, May 21, 2021 10:46:13 PM(UTC)
fabfab10
Italy
That's pretty strange, we have at least 10 different systems with Decklink duo 2 or quad 2 under windows 10 and they all work flawlessy.
May i know more details about the system?
Have you tried a different PCI slot, there are differences between them.
Babbit
#7 Posted : Friday, May 21, 2021 11:45:20 PM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
I used to have this problem with my Decklink Duo 2. It would take a few right-click/reset maneuvers for it to pick up the video. It hasn't been a thing for me lately, and unfortunately I can't recall what's changed on my system that would be considered the fix. I do update motherboard, graphics card, and Decklink drivers fairly routinely.
I do seem to remember that when the problem was more prevalent that certain standards were more prone to the problem occurring. For example, it wouldn't happen all the time at 1080p59.94, but it was a guarantee at 720p59.94. That very well could have been because the video coming into the Decklink was still 1080p59.94.
Speegs
#8 Posted : Saturday, May 22, 2021 1:38:14 PM(UTC)
Speegs
I was thinking of buying a Blackmagic Design Decklink Quad 2.
This thread is giving me second thoughts. I love Magewell, but they don't seem to have an equivalent card unfortunately with 8 SDI IN/OUT.
Maybe AJA is a better option.
AudioGreg
#9 Posted : Saturday, May 22, 2021 1:51:50 PM(UTC)
AudioGreg
Was thanked: 20 time(s) in 18 post(s)
I'm another DUO2 user that's never had an issue, seems like a solid piece of hardware. System specs for comparison...
Dell 3930/i9-9900K/32Gb/QuadroRTX4000
Windows 10 20H2 v19042.928
Desktop Video v12.0
vMix v24.0.0.56
Good luck finding your issue.
Babbit
#10 Posted : Saturday, May 22, 2021 2:32:28 PM(UTC)
Babbit
I don't think AJA makes an 8 I/O card. At least not in the Kona line.
fabfab10
#11 Posted : Saturday, May 22, 2021 6:21:14 PM(UTC)
fabfab10
Italy
Actually AJA do manufactur an 8 port card, it's under the development section called Corvid 88.
https://www.aja.com/products/corvid-88
Totally different price range by the way, and it's available through their system integrator's network.
Usually BMD Decklink cards works right off the box, on some systems you have to fight at the beginning, like manually deleting all instanced in system resources and be sure the firmware is updated when you install a different software package. PCI slot is also very important and availability of necessary PCI lanes counting all needs of the system.
thanks 1 user thanked fabfab10 for this useful post.
Speegs on 5/23/2021(UTC)
J Miller
#12 Posted : Sunday, May 23, 2021 3:33:32 AM(UTC)
J Miller
Canada
I had a similar issue recently with a usually stable system, with a camera input needing frequent resets. After some troubleshooting, I replaced the cable from the camera to the card. Fixed. If you've not already tried a new cable or cables, might be worth a shot.
jsawyer77
#13 Posted : Thursday, June 3, 2021 11:30:09 AM(UTC)
jsawyer77
This is a custom system. The camera going hdmi to a black magic converter that takes it from hdmi to sdi.
Asus prime Z490M-Plus board
32 MB of memory
M2 ssd
The card is plugged into the PCI X16 slot
Any suggestions on different cards that I can try wit 4 SDI inputs?
