Unity+IFB+Virtual Greenroom
Joined: 5/19/2021(UTC) Posts: 17  Was thanked: 1 time(s) in 1 post(s)
Hi - I have a question about setting up vMix and Unity intercom for IFB from the director, not the person running vmix, to people on vmix calls. I have Unity intercom working and program audio going into it via Dante. I also have an IFB channel that is routed into vmix which I would like to use for anyone on com to be able to speak with the presetners (provided I give them access to that Unity channel). I know this can be done because I've seen it in action. I'm just not sure of the exact routing/triggers.
Before the presenters go live they in a virtual green room with their mics active on BusA and a program feed coming in. Their audio return is also BusA. The Unity IFB channel is also on BusA so the producer can speak to them whenever they want just by activating that channel on the Unity client.
Where the wheels come off is during rehearsals, when the presenters are live I need to change their return audio to another bus so they don't hear chatter from presenters who are still in the greenroom but I still need the ability for producers or directors (not the engineer) to talk to them. Their return needs to be a mix minus + the IFB channel, but the IFB channel can not ever go to the master bus. There aren't enough buses to create a return for each presenter.
Is this possible without an external audio console?
The answer is to setup a bus as mix minus for the program audio send to Unity. Its a little annoying to remember to manually turned on that bus for every input but it works. Producers can talk to presenters both before and while they are live and don't hear themselves on the return.
Thanks for the input. I am using a U-Phoria UMC202HD for capturing church sounds system input. That is coming in via USB.
Joined: 11/23/2020(UTC) Posts: 249  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: grippingconfront  Thanks for the input. I am using a U-Phoria UMC202HD for capturing church sounds system input. That is coming in via USB. Was there a question of some sort implied there? Only asking in case there is a question that I don't seem to be able to see. (P.S. I've always called it a Behringer UMC204HD, never noticed the "U-Phoria" on it until you used it. Gonna plead the "rose is a rose by any other name excuse.)
