Streaming with Globalmeet (PGI) - ERROR
Hello evryone,
I try to connect to globalmeet but it's seems that I have a connection issue... I had the 1935 port on my firewall exceptions rule but the error still the same
Can you help me ? Do you have any issues with stream that look like that ?
FFMPEG1.Exited Streaming [rtmp @ 0517aea0] Cannot open connection tcp://ingest-uk1.webcasts.com:1935 rtmp://ingest-uk1.webcasts.com/abr_live/mp4:T4IB2OOVV4: Unknown error
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (77% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (80% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (82% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (85% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (87% of size: 128000000 [rtbufsize parameter])! frame dropped! Last message repeated 140 times [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (89% of size: 128000000 [rtbufsize parameter])! frame dropped! Last message repeated 18 times [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (92% of size: 128000000 [rtbufsize parameter])! frame dropped! Last message repeated 38 times [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! Last message repeated 4 times [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (97% of size: 128000000 [rtbufsize parameter])! frame dropped! Last message repeated 7 times [rtmp @ 0517aea0] Cannot open connection tcp://ingest-uk1.webcasts.com:1935 rtmp://ingest-uk1.webcasts.com/abr_live/mp4:T4IB2OOVV4: Unknown error [dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (97% of size: 128000000 [rtbufsize parameter])! frame dropped! Last message repeated 1 times
Thank you !
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
I would try to ping the server. But it might be that ICMP packets are rejected so ping wouldn't work in that case. The other option is to nslookup that server. (Is DNS working) If all that is successfull you might want to telnet [server] [port] (Does the server provide the port open)
From my end ping ingest-uk1.webcasts.com Ping wird ausgeführt für ingest-uk1.webcasts.com [3.251.93.21] mit 32 Bytes Daten: Antwort von 3.251.93.21: Bytes=32 Zeit=34ms TTL=46 Antwort von 3.251.93.21: Bytes=32 Zeit=33ms TTL=46 Antwort von 3.251.93.21: Bytes=32 Zeit=33ms TTL=46 Antwort von 3.251.93.21: Bytes=32 Zeit=34ms TTL=46
C:\Users\Jens>nslookup ingest-uk1.webcasts.com Server: dns.google Address: 8.8.8.8
Nicht autorisierende Antwort: Name: ingest-uk1.webcasts.com Address: 3.251.93.21
C:\Users\Jens>telnet ingest-uk1.webcasts.com 1935 is successful as well.
