MediaFactory
#1 Posted : Tuesday, May 18, 2021 12:00:38 AM(UTC)
MediaFactory
Hello evryone,
I try to connect to globalmeet but it's seems that I have a connection issue... I had the 1935 port on my firewall exceptions rule but the error still the same
Can you help me ? Do you have any issues with stream that look like that ?
FFMPEG1.Exited
Streaming
[rtmp @ 0517aea0] Cannot open connection tcp://ingest-uk1.webcasts.com:1935
rtmp://ingest-uk1.webcasts.com/abr_live/mp4:T4IB2OOVV4: Unknown error
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (77% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (80% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (82% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (85% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (87% of size: 128000000 [rtbufsize parameter])! frame dropped!
Last message repeated 140 times
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (89% of size: 128000000 [rtbufsize parameter])! frame dropped!
Last message repeated 18 times
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (92% of size: 128000000 [rtbufsize parameter])! frame dropped!
Last message repeated 38 times
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped!
Last message repeated 4 times
[dshow @ 02707fc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (97% of size: 128000000 [rtbufsize parameter])! frame dropped!
Last message repeated 7 times
Last message repeated 1 times
Thank you !
mavik
#2 Posted : Tuesday, May 18, 2021 1:50:04 AM(UTC)
mavik
I would try to ping the server. But it might be that ICMP packets are rejected so ping wouldn't work in that case.
The other option is to nslookup that server. (Is DNS working)
If all that is successfull you might want to telnet [server] [port] (Does the server provide the port open)
mavik
#3 Posted : Tuesday, May 18, 2021 1:54:46 AM(UTC)
mavik
From my end
ping ingest-uk1.webcasts.com
Ping wird ausgeführt für ingest-uk1.webcasts.com [3.251.93.21] mit 32 Bytes Daten:
Antwort von 3.251.93.21: Bytes=32 Zeit=34ms TTL=46
Antwort von 3.251.93.21: Bytes=32 Zeit=33ms TTL=46
C:\Users\Jens>nslookup ingest-uk1.webcasts.com
Server: dns.google
Address: 8.8.8.8
Nicht autorisierende Antwort:
Address: 3.251.93.21
C:\Users\Jens>telnet ingest-uk1.webcasts.com 1935
is successful as well.
