Instant Replay
External audio (dante) to replay inputs
Hi! We currently use vmix exclusivly for replay with 8 inputs via our Atem Constellation outputs and hence we only get the same PGM audio on all the SDI signals.
We'd like to know if there is a way to combine a video input from our decklink cards with a Dante audio input (Virtual soundcard) and have those as inputs in the replay system? We tried to add an audio input and add the video as a multiview layer on top - and it works great in VMIX video mixer interface but we're unable to select them as inputs in the replay config ( We get an error popup saying "Video Source Not Ready" )
Is there another way to solve it?
Best regards,
Ludvig Fjell Qruxel Productions
Joined: 8/15/2013(UTC) Posts: 107   Location: Could be Australia could be Europe/UK! Thanks: 2 times Was thanked: 9 time(s) in 9 post(s)
I don't think you can with Decklink card... however when you use a Yuan High Tech capture card you can choose a separate audio device for the video input. (have not tested this, just noticed the option when adding an input)
Bit of a late response but I encountered this issue while using vMix replays with a BMD Decklink Quad 2 and Dante audio. My solution was to select "legacy devices" in the drop down menu for the camera input and choose "Blackmagic Capture WDM" - this actually allows you to select a separate audio source to connect to a camera channel, rather than being forced to use embedded audio. I linked an image below of an example of the settings.  Seems that the up-to-date "Declink Quad" input forces you onto embedded no matter what... oh well, hopefully BMD/vMix don't stop supporting their legacy systems.
Instant Replay
