data source shortcut for excel
I am having issues getting the shortcut I set up for DataSourceNextRow and/or DataSourcePreviousRow to work at all. I have seen how some people have done this programmatically but I am no programmer. I just need the shortcut to advance to the next row in my Excel spreadsheet. The file name I am using is test_lyrics.xlsx and vMix imports it and I can see the data. If I advance manually in the Data Source Manager, it shows up on my output but If I close the data manager and try to advance the row usng the shortcut it is not working. I hope I am being clear enough. I really need this to work as our Pastor is not happy with using an inset of the PowerPoint slides we use during the service for the congregation.
Bill
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Have you referenced the shortcut to the NAME of the data source table like Excle/CSV or one you created ?
Originally Posted by: doggy  Have you referenced the shortcut to the NAME of the data source table like Excle/CSV or one you created ? I put C:\Users\lcpc\Desktop\test_lyrics.xlsx,Sheet1 in the Value: field. Is this correct?
Originally Posted by: btc9183  Originally Posted by: doggy  Have you referenced the shortcut to the NAME of the data source table like Excle/CSV or one you created ? I put C:\Users\lcpc\Desktop\test_lyrics.xlsx,Sheet1 in the Value: field. Is this correct? No, need to use the name specified with the Edit Data Source  dts.JPG (28kb) downloaded 3 time(s).
Originally Posted by: doggy  Originally Posted by: btc9183  Originally Posted by: doggy  Have you referenced the shortcut to the NAME of the data source table like Excle/CSV or one you created ? I put C:\Users\lcpc\Desktop\test_lyrics.xlsx,Sheet1 in the Value: field. Is this correct? No, need to use the name specified with the Edit Data Source  dts.JPG (28kb) downloaded 3 time(s). So this is what I have set up: The Data source:  Shortcut setup:  I think that is the right way to set it up but it does not work. What am I doing wrong?
Joined: 1/2/2021(UTC) Posts: 2  Location: San Antonio
As doggy mentioned, you need to use the name of your data source. So, your value should be:
Excel/CSV,Sheet1
Lou
Originally Posted by: btc9183  I think that is the right way to set it up but it does not work. What am I doing wrong?
Easy answer: You are thinking wrong and are NOT listening !
