btc9183
#1 Posted : Friday, May 7, 2021 12:32:36 PM(UTC)
btc9183
I am having issues getting the shortcut I set up for DataSourceNextRow and/or DataSourcePreviousRow to work at all. I have seen how some people have done this programmatically but I am no programmer. I just need the shortcut to advance to the next row in my Excel spreadsheet. The file name I am using is test_lyrics.xlsx and vMix imports it and I can see the data. If I advance manually in the Data Source Manager, it shows up on my output but If I close the data manager and try to advance the row usng the shortcut it is not working. I hope I am being clear enough. I really need this to work as our Pastor is not happy with using an inset of the PowerPoint slides we use during the service for the congregation.
Bill
#2 Posted : Friday, May 7, 2021 5:23:06 PM(UTC)
Have you referenced the shortcut to the NAME of the data source table like Excle/CSV or one you created ?
btc9183
#3 Posted : Saturday, May 8, 2021 10:26:52 AM(UTC)
btc9183
I put C:\Users\lcpc\Desktop\test_lyrics.xlsx,Sheet1 in the Value: field. Is this correct?
#4 Posted : Saturday, May 8, 2021 11:10:32 AM(UTC)
No, need to use the name specified with the Edit Data Source
btc9183
#5 Posted : Sunday, May 9, 2021 3:52:40 AM(UTC)
btc9183
So this is what I have set up:
The Data source:
Data source
Shortcut setup:
Shortcut
I think that is the right way to set it up but it does not work. What am I doing wrong?
LNavarro
#6 Posted : Sunday, May 9, 2021 9:17:16 PM(UTC)
LNavarro
As doggy mentioned, you need to use the name of your data source. So, your value should be:
Excel/CSV,Sheet1
Lou
#7 Posted : Sunday, May 9, 2021 9:20:07 PM(UTC)
Easy answer: You are thinking wrong and are NOT listening !
Guest (4)
