Rank:: Newbie
Joined: 5/1/2021(UTC) Posts: 2  Location: Los Angeles
Hi All,
I'm pretty new to vMix, so I would love some advice. Has anyone successfully used an 8 Channel Audio Interace with vMix? We have a live stream coming up that requires 5 different xlr inputs, so the recommended 4 Channel units won't do the trick. I am currently looking at the Scarlett18i20, but I'm open to anything.
Thank you for the help! I really appreciate it.
Joined: 10/31/2020(UTC) Posts: 193  Thanks: 5 times Was thanked: 43 time(s) in 42 post(s)
I know of at least one person who uses a Midas MR18 (18 inputs/outputs, configurable). I think I remember someone using a Scarlett 18i20 as well.
You could always use a mixer, too, if that fits into your workflow.
I use a Tascam US-16x08, but I would have though the Scarlett 18i20 would have been just as good. Have you tried it?
Rank:: Newbie
I haven't tried out the Scarlett 18i20 yet. I was hoping someone had experience with it already, but the Tascam sounds promising! I think we'll probably try with that first. Thanks!
Joined: 7/1/2020(UTC) Posts: 104  Location: Earth Was thanked: 23 time(s) in 20 post(s)
I sometimes use a Behringer XR18, same unit as the Midas MR18. Provides up to 18 inputs, and is also a standalone mixer. Much more functionality than just a USB interface.
