How to transmit with audio in 32 bit 48000 hz?
Joined: 4/24/2021(UTC) Posts: 3  Location: Rio de Janeiro
I change my audio from 16 bit to 32 and it doesn't let me start a transmission, an error message appears. I need it urgently, the audio at 16 is not as good as I want
Just curious, but what aspect of 16bit audio do you find unsatisfactory for broadcasting, given that it's pretty much the standard for broadcasting in general?
Originally Posted by: zenvideo  Just curious, but what aspect of 16bit audio do you find unsatisfactory for broadcasting, given that it's pretty much the standard for broadcasting in general? I worked with obs and used it in 24 bit, I felt a difference, I thought it was bad. I can't change it, this message appears: [img=https://drive.google.com/file/d/1IzcH1fxFaGRWh4YjToL3MmdniUjx5zK0/view?usp=sharing]https://drive.google.com/file/d/1IzcH1fxFaGRWh4YjToL3MmdniUjx5zK0/view?usp=sharing[/img]
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Yeah, I saw the same error on a project when we set the project to 32bit and sent audio via Dante to an external audio mixing desk. For streaming & recording, we used a 2nd PC which received the PGM via an external SDI output.
So, despite the theoretical gain in quality from 32bit processing, we don't do that any more !
