Booth
#1 Posted : Wednesday, June 3, 2020 6:46:36 PM(UTC)
Booth
Scenario:
  • Most audio for the stream is sourced from a dedicated mixer, which represents an audio input in vMix.
  • Audio is not utilized from Camera inputs; cameras are video only.
  • Some cameras are HDMI with little latency.
  • Other cameras use NDI wirelessly and have greater latency
  • Lip-sync issues result
The ability to change the audio latency via a script or trigger will enable audio to be easily synchronized when changing between cameras with different latencies.
Adding an API command for setting an Audio Delay on an input in vMix resolves this issue by allowing the audio delay to be set on transition in and out.
MZBC
#2 Posted : Wednesday, April 21, 2021 11:46:03 PM(UTC)
MZBC
+1
#3 Posted : Thursday, April 22, 2021 12:26:43 AM(UTC)
Would a plugin (Audio delay )not be useful ?
billh2020
#4 Posted : Thursday, November 11, 2021 10:50:04 AM(UTC)
billh2020
+1
Cainnech
#5 Posted : Tuesday, December 21, 2021 1:21:31 PM(UTC)
Cainnech
+1
