2 Pages12>
#1 Posted : Saturday, December 12, 2020 9:47:19 PM(UTC)
Was thanked: 996 time(s) in 826 post(s)
While not directly one can change a "fake" rectangle color change using shortcuts, a script or manually
just create a fake rectangle by using a TextBlock filled with ASCII character 219
Change the color using the SetTextColour with a shortcut or in the title editor color picker
To automate it use a script that checks the color data in a hidden textblock
or just use regular rectangles and change them in the title designer or replace images used as background ;-)
thanks 5 users thanked doggy for this useful post.
sontoloyo on 12/13/2020(UTC), Rinsky on 12/16/2020(UTC), monamiga on 2/4/2021(UTC), shuizhiyu on 4/18/2021(UTC), minhdowndown on 10/2/2021(UTC)
#2 Posted : Saturday, December 12, 2020 9:59:14 PM(UTC)
Ah ah ! That's how I dealt with yellow or red cards for sport graphics in vMix UTC. So simple !
Rinsky
#3 Posted : Wednesday, December 16, 2020 2:15:13 AM(UTC)
Rinsky
Such a stupid and great workaround! Thank you! :-D
blue28
#4 Posted : Friday, December 18, 2020 7:23:58 PM(UTC)
blue28
great, how you do this
#5 Posted : Friday, December 18, 2020 7:58:46 PM(UTC)
it's described in the post !
blue28 on 1/4/2021(UTC)
hive8
#6 Posted : Saturday, February 27, 2021 8:54:44 AM(UTC)
hive8
That's a great method of doing that, how would I change the color of a gradient, that is bound to a text element and expands or substracts with the number of characters typed in the text field. I still think vMix should expose the color value of these items.
#7 Posted : Saturday, February 27, 2021 9:14:10 AM(UTC)
Don't push your luck LOL
hive8
#8 Posted : Friday, March 5, 2021 6:00:38 PM(UTC)
hive8
One can dream :)
shuizhiyu
#9 Posted : Sunday, April 18, 2021 1:40:45 PM(UTC)
shuizhiyu
China
I'd like to ask you something
Ask colordata1. Text how to change the color code ?
thank you
You can upload one colorrect.gtzip ?
#10 Posted : Sunday, April 18, 2021 4:02:06 PM(UTC)
thank you
Right click the title editor and select another color or type it in just as one would otherwise change a color of text
As for the colordata1 specifically , the content is read by a script to perform a color change function
See comments in the video (YT)
Peter1000
#11 Posted : Sunday, April 18, 2021 5:52:32 PM(UTC)
Peter1000
Switzerland
Was thanked: 79 time(s) in 60 post(s)
You can use argb values or colornames from here https://www.w3schools.com/colors/colors_names.asp
Code:
API.Function("SetTextColour",Input:="titlename.gtzip",SelectedName:="colordata1.Text",Value:="transparent")
thanks 1 user thanked Peter1000 for this useful post.
shuizhiyu
#12 Posted : Sunday, April 18, 2021 6:35:52 PM(UTC)
shuizhiyu
China
thank you
Thank you for your answer
I watched the comments (YT) in the video seriously
I understand a little bit, but how to write functions in scripts.
Can you tell me what the code is?
shuizhiyu
#13 Posted : Sunday, April 18, 2021 6:37:15 PM(UTC)
shuizhiyu
China
Code:
Thank you
Thank you for your code
But this code doesn't seem to work
#14 Posted : Monday, April 19, 2021 12:27:14 AM(UTC)
Code:
Thank you
Blindly copying code is not going to work
Check out the same named shortcut and it needs and compare that to that function
also https://forums.vmix.com/...86-Scripting-for-Dummies
shuizhiyu
#15 Posted : Monday, April 19, 2021 4:56:23 PM(UTC)
shuizhiyu
China
Code:
Thank you
Thank you
ciberego
#16 Posted : Wednesday, September 1, 2021 9:33:30 AM(UTC)
ciberego
Portugal
Can you please tell me how to script to get info from colordata to fill information of the rectangle?
#17 Posted : Wednesday, September 1, 2021 4:26:52 PM(UTC)
Code:
dim color as string = Input.Find("Title.gtzip").Text("Colordat1.Text")
Also see helpfiles and post "scripting for dummies" in this forum
andreypetr
#18 Posted : Wednesday, September 1, 2021 9:42:14 PM(UTC)
andreypetr
Hey @doggy! Is it possible to change the size (width) of rectangle within GT Title? I wanted to make a simple progress bar.
#19 Posted : Wednesday, September 1, 2021 10:48:17 PM(UTC)
Need a slightly different approach for a progress bar like in this video ( say fill it with "invisible" periods, or have the rectangle on top of it )
See also this post
https://forums.vmix.com/...c-progress-bar#post93365
andreypetr
#20 Posted : Thursday, September 2, 2021 3:39:31 AM(UTC)
andreypetr
Guest (4)
2 Pages12>
