GT
Rectangle color change using data
Joined: 12/27/2012(UTC) Posts: 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
While not directly one can change a "fake" rectangle color change using shortcuts, a script or manually just create a fake rectangle by using a TextBlock filled with ASCII character 219 Change the color using the SetTextColour with a shortcut or in the title editor color picker To automate it use a script that checks the color data in a hidden textblock or just use regular rectangles and change them in the title designer or replace images used as background ;-)
 5 users thanked doggy for this useful post.
Ah ah ! That's how I dealt with yellow or red cards for sport graphics in vMix UTC. So simple !
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Such a stupid and great workaround! Thank you! :-D
Joined: 1/27/2018(UTC) Posts: 15  Location: Bangladesh Thanks: 19 times
Originally Posted by: blue28  great, how you do this it's described in the post !
Joined: 11/14/2012(UTC) Posts: 10 Location: Los Angeles
That's a great method of doing that, how would I change the color of a gradient, that is bound to a text element and expands or substracts with the number of characters typed in the text field. I still think vMix should expose the color value of these items.
Originally Posted by: hive8  how would I change the color of a gradient, that is bound to a text element and expands or substracts with the number of characters typed in the text field. Don't push your luck LOL
Originally Posted by: shuizhiyu
I'd like to ask you something
Ask colordata1. Text how to change the color code ?
thank you
Right click the title editor and select another color or type it in just as one would otherwise change a color of text As for the colordata1 specifically , the content is read by a script to perform a color change function See comments in the video (YT)
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
 1 user thanked Peter1000 for this useful post.
Originally Posted by: shuizhiyu  Originally Posted by: Peter1000  Thank you Thank you for your code But this code doesn't seem to work Blindly copying code is not going to work Check out the same named shortcut and it needs and compare that to that function also https://forums.vmix.com/...86-Scripting-for-Dummies
Joined: 2/13/2021(UTC) Posts: 4  Location: Porto Thanks: 1 times
Originally Posted by: doggy  While not directly one can change a "fake" rectangle color change using shortcuts, a script or manually just create a fake rectangle by using a TextBlock filled with ASCII character 219 Change the color using the SetTextColour with a shortcut or in the title editor color picker To automate it use a script that checks the color data in a hidden textblock or just use regular rectangles and change them in the title designer or replace images used as background ;-) Can you please tell me how to script to get info from colordata to fill information of the rectangle? Thanks
Originally Posted by: ciberego  Can you please tell me how to script to get info from colordata to fill information of the rectangle? Thanks
Code:dim color as string = Input.Find("Title.gtzip").Text("Colordat1.Text")
Also see helpfiles and post "scripting for dummies" in this forum
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
Hey @doggy! Is it possible to change the size (width) of rectangle within GT Title? I wanted to make a simple progress bar.
Originally Posted by: andreypetr  Hey @doggy! Is it possible to change the size (width) of rectangle within GT Title? I wanted to make a simple progress bar. Need a slightly different approach for a progress bar like in this video ( say fill it with "invisible" periods, or have the rectangle on top of it ) See also this post https://forums.vmix.com/...c-progress-bar#post93365
Joined: 9/2/2021(UTC) Views messages in topic : 11  Location: VN Thanks: 4 times
Hello, sorry for bump this thread up but is there a script way to check if the input color value is valid? I accidently typed the wrong hex color and the script stop immediately.
Originally Posted by: minhdowndown  Hello, sorry for bump this thread up but is there a script way to check if the input color value is valid? I accidently typed the wrong hex color and the script stop immediately. Need to build error trapping within your script ! Easiest is using a Try Catch statement
Originally Posted by: doggy  Originally Posted by: minhdowndown  Hello, sorry for bump this thread up but is there a script way to check if the input color value is valid? I accidently typed the wrong hex color and the script stop immediately. Need to build error trapping within your script ! Easiest is using a Try Catch statement Thanks very much. Just a little off-topic, how did you made page-to-page GT title like this? I tried some ways to make one like this but failed.
Originally Posted by: minhdowndown  Thanks very much. Just a little off-topic, how did you made page-to-page GT title like this? I tried some ways to make one like this but failed.
As mentioned in the video description : using OnDataChange within the title animation  fadetitle.JPG (44kb) downloaded 15 time(s).Data Source is like Name1, Subject... Name2, Subject... Name3, Subject...
GT
