Javier Cab
#1 Posted : Saturday, April 17, 2021 6:13:42 PM(UTC)
Javier Cab
Spain
My name is Javier. When I create a virtual set and inside a vmap I put the camera, the image comes out with saw teeth. Probably it´s the Vmap image that I create but I´m not sure. Someone same problem? Some one can help?
#2 Posted : Saturday, April 17, 2021 6:19:54 PM(UTC)
It's called UVmap and yes probably created wrong , How did you create the UVmap ?
Javier Cab
#3 Posted : Saturday, April 17, 2021 7:17:23 PM(UTC)
Javier Cab
Spain
The image is created by Inkscape (do you know the software?). The UVmap screen for the cam is situated in the image. The settings are: 1920x1080pix, in PNG, RGBA_16, Z_NO_COMPRESION, ppp of pHYs 0.00, Antialiasing CAIRO_ANTIAS_GOOD (default).
Javier Cab
#4 Posted : Saturday, April 17, 2021 7:20:18 PM(UTC)
Javier Cab
Spain
It´s 1920 to 291.29ppp and 1080 to 291.29ppp
#5 Posted : Saturday, April 17, 2021 7:46:37 PM(UTC)
I hope you did not mean UVmap within another image as one!
The way a UV map works @3:55:
?t=238
Simply download an existing proper UVmap https://forums.vmix.com/...-UV-map-create#post10663
or create it as it should (Photoshop, Gimp) https://forums.vmix.com/...p-from-scratch#post87962
There are tutorial videos regarding UVmaps and virtual sets and your problem has come up multiple times in this forum also (SEARCH)
Javier Cab
#6 Posted : Saturday, April 17, 2021 8:56:24 PM(UTC)
Javier Cab
Spain
?t=238
thankyou. this information will be enough
Javier Cab
#7 Posted : Monday, April 19, 2021 5:11:38 PM(UTC)
Javier Cab
Spain
?t=238
Thank You doggy. It works perfectly now. See you!
