cam in vmap comes out with saw teeth
My name is Javier. When I create a virtual set and inside a vmap I put the camera, the image comes out with saw teeth. Probably it´s the Vmap image that I create but I´m not sure. Someone same problem? Some one can help?
Originally Posted by: Javier Cab  My name is Javier. When I create a virtual set and inside a vmap I put the camera, the image comes out with saw teeth. Probably it´s the Vmap image that I create but I´m not sure. Someone same problem? Some one can help? It's called UVmap and yes probably created wrong , How did you create the UVmap ?
Originally Posted by: doggy  Originally Posted by: Javier Cab  My name is Javier. When I create a virtual set and inside a vmap I put the camera, the image comes out with saw teeth. Probably it´s the Vmap image that I create but I´m not sure. Someone same problem? Some one can help? It's called UVmap and yes probably created wrong , How did you create the UVmap ? The image is created by Inkscape (do you know the software?). The UVmap screen for the cam is situated in the image. The settings are: 1920x1080pix, in PNG, RGBA_16, Z_NO_COMPRESION, ppp of pHYs 0.00, Antialiasing CAIRO_ANTIAS_GOOD (default).
Originally Posted by: Javier Cab  Originally Posted by: doggy  Originally Posted by: Javier Cab  My name is Javier. When I create a virtual set and inside a vmap I put the camera, the image comes out with saw teeth. Probably it´s the Vmap image that I create but I´m not sure. Someone same problem? Some one can help? It's called UVmap and yes probably created wrong , How did you create the UVmap ? The image is created by Inkscape (do you know the software?). The UVmap screen for the cam is situated in the image. The settings are: 1920x1080pix, in PNG, RGBA_16, Z_NO_COMPRESION, ppp of pHYs 0.00, Antialiasing CAIRO_ANTIAS_GOOD (default). It´s 1920 to 291.29ppp and 1080 to 291.29ppp
Originally Posted by: doggy  thankyou. this information will be enough
Originally Posted by: Javier Cab  Originally Posted by: doggy  thankyou. this information will be enough Thank You doggy. It works perfectly now. See you!
