tom0101
#1 Posted : Thursday, April 1, 2021 7:46:39 PM(UTC)
tom0101
Austria
Hi all,
i use this script to control the PTZ API of my AXIS Cameras.
e.g.: http://192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2
The Script looks like this (thanks kgoodyer):
Dim webStream As Stream
Dim webResponse = ""
Dim req As HttpWebRequest
Dim res As HttpWebResponse
req = CType(WebRequest.Create("http://192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2"), HttpWebRequest)
res = CType(req.GetResponse(), HttpWebResponse)
webStream = res.GetResponseStream() ' Get Response
Dim webStreamReader As New StreamReader(webStream)
While webStreamReader.Peek >= 0
webResponse = webStreamReader.ReadToEnd()
End While
The Problem is, i don't know how to do a request with a password,
http://USER:PASSWORT@192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2
does not work.
So is there a possibility to send user and password with a HttpWebRequest?
Best, Thomas
kross
#2 Posted : Friday, April 2, 2021 7:56:19 AM(UTC)
kross
Was thanked: 44 time(s) in 43 post(s)
I don't have an Axis camera, but I did some searching, and it appears Axis cameras require Digest authentication.
Here's a C# example, it should be easy enough to translate to VB.Net
https://stickler.de/en/i...-authentication-c-csharp
tom0101
#3 Posted : Wednesday, April 7, 2021 9:16:51 PM(UTC)
tom0101
Austria
Thank you for the answer, but unfortunately i am not able to translate the c# example to VB.Net.
Maybe anyone can do?
Thanks,
Tom
kross
#4 Posted : Thursday, April 8, 2021 4:45:43 AM(UTC)
kross
I'm a C++ and C# software engineer, but I don't work with VB.Net. So here's a stab by me, completely untested, I don't even know if it would compile.
Dim uri as New Uri("http://192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2")
Dim username as String = "PutYourUsernameHere"
Dim password as String = "PutYourPasswordHere"
req = CType(WebRequest.Create(uri), HttpWebRequest)
Dim myNetworkCredential As New NetworkCredential(username, password)
Dim myCredentialCache As New CredentialCache
myCredentialCache.Add(uri, "Digest", myNetworkCredential)
req.PreAuthenticate = true
req.Credentials = myCredentialCache
End While
If there are syntax or compile errors, someone who actually knows VB.Net will have to take a look at it.
Hope this helps!
-- Kevin
tom0101
#5 Posted : Friday, April 23, 2021 5:46:49 PM(UTC)
tom0101
Austria
I still couldn't get it working.
Anyone else who knows how to get this done in VB.Net?
Whisnant4154
#6 Posted : Thursday, May 6, 2021 3:39:50 PM(UTC)
Whisnant4154
Jenkins provides machine-consumable remote access API to its functionalities. Currently trigger a new build In order to make this command work, you need to configure your Jenkins job to take a file in environments where XML manipulation is tedious (such as shell script.) Username/password based authentication.
mygiftcardsite
