3rd Party Software and Development
Script to trigger an API command with user and password
Joined: 11/17/2020(UTC) Posts: 5  Location: Villach Thanks: 4 times
Hi all, i use this script to control the PTZ API of my AXIS Cameras. e.g.: http://192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2The Script looks like this (thanks kgoodyer): Quote: Dim webStream As Stream Dim webResponse = "" Dim req As HttpWebRequest Dim res As HttpWebResponse req = CType(WebRequest.Create("http://192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2"), HttpWebRequest) res = CType(req.GetResponse(), HttpWebResponse) webStream = res.GetResponseStream() ' Get Response Dim webStreamReader As New StreamReader(webStream) While webStreamReader.Peek >= 0 webResponse = webStreamReader.ReadToEnd() End While
The Problem is, i don't know how to do a request with a password, Quote:http://USER:PASSWORT@192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2 does not work. So is there a possibility to send user and password with a HttpWebRequest? Best, Thomas
Joined: 10/31/2020(UTC) Posts: 198  Thanks: 6 times Was thanked: 44 time(s) in 43 post(s)
Thank you for the answer, but unfortunately i am not able to translate the c# example to VB.Net.
Maybe anyone can do?
Thanks, Tom
I'm a C++ and C# software engineer, but I don't work with VB.Net. So here's a stab by me, completely untested, I don't even know if it would compile. Quote: Dim webStream As Stream Dim webResponse = "" Dim req As HttpWebRequest Dim res As HttpWebResponse
Dim uri as New Uri("http://192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2") Dim username as String = "PutYourUsernameHere" Dim password as String = "PutYourPasswordHere"
req = CType(WebRequest.Create(uri), HttpWebRequest)
Dim myNetworkCredential As New NetworkCredential(username, password)
Dim myCredentialCache As New CredentialCache myCredentialCache.Add(uri, "Digest", myNetworkCredential)
req.PreAuthenticate = true req.Credentials = myCredentialCache
If there are syntax or compile errors, someone who actually knows VB.Net will have to take a look at it. Hope this helps! -- Kevin
I still couldn't get it working.
Anyone else who knows how to get this done in VB.Net?
Jenkins provides machine-consumable remote access API to its functionalities. Currently trigger a new build In order to make this command work, you need to configure your Jenkins job to take a file in environments where XML manipulation is tedious (such as shell script.) Username/password based authentication. mygiftcardsite
