Feature Requests
Shortcuts function 'Preview Last Input' and delay between functions
Joined: 6/15/2015(UTC) Posts: 26  Location: Athens, Greece Thanks: 21 times Was thanked: 1 time(s) in 1 post(s)
I hope it gets possible to see a shortcut function for previewing the last input. Just for the sake of automation There is a'PreviewInputPrevious' but it's meant for a totally different use.
I also came to a point where a shortcut function for inserting a delay or a pause in miliseconds between 2 function events was so important for the automation. Like when you press a key on the controller and there is a chain of functions to be executed but with certain timings. For example: Fade/ (insert pause ) / overlay in (insert pause) / overlay off (insert pause) etc
You are doing a great job. Kind regards
for an automation, you also can use scripts there you have no problems with pause
 2 users thanked xaver for this useful post.
Originally Posted by: xaver  for an automation, you also can use scripts there you have no problems with pause Still we could use those new functions i mentioned for new possibilities, whether its a script, a shortcut, or even a trigger.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Sounds to me that the scripting possibilities and the available info from the API XML would be more than enough to achieve these goals
Feature Requests
