stergi
#1 Posted : Wednesday, April 7, 2021 9:53:26 PM(UTC)
stergi
I hope it gets possible to see a shortcut function for previewing the last input. Just for the sake of automation There is a'PreviewInputPrevious' but it's meant for a totally different use.
I also came to a point where a shortcut function for inserting a delay or a pause in miliseconds between 2 function events was so important for the automation. Like when you press a key on the controller and there is a chain of functions to be executed but with certain timings. For example: Fade/ (insert pause ) / overlay in (insert pause) / overlay off (insert pause) etc
You are doing a great job.
Kind regards
xaver
#2 Posted : Wednesday, April 7, 2021 11:35:33 PM(UTC)
xaver
for an automation, you also can use scripts
there you have no problems with pause
thanks 2 users thanked xaver for this useful post.
doggy on 4/7/2021(UTC), stergi on 4/8/2021(UTC)
stergi
#3 Posted : Thursday, April 8, 2021 1:15:19 AM(UTC)
stergi
Still we could use those new functions i mentioned for new possibilities, whether its a script, a shortcut, or even a trigger.
#4 Posted : Thursday, April 8, 2021 2:07:05 AM(UTC)
Was thanked: 1001 time(s) in 828 post(s)
Sounds to me that the scripting possibilities and the available info from the API XML would be more than enough to achieve these goals
