Please tell me. I have machine I9-10900K, 128 GB Ram, RTX3080 but my GPU doesn't have video output sync. Sometimes I use my maschine with led wall and I need output SYNC. Now I have the opportunity to change RTX3080 for RTX5000. Will the rtx50000 quadro work well with VMIX? Please help because I don't know what to do
I went from using my RTX 3090 to using a RTX 5000 and yes it works great, with the added benefit of taking advantage of NVENC for more simultaneous multicorder/record/streams. I did notice slightly slower load times when opening a show compared to the RTX 3090 but thats to be expected given the difference in ram and architecture.
Joined: 3/28/2016(UTC) Posts: 172   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
Originally Posted by: Majkelpl-CM  Please tell me. I have machine I9-10900K, 128 GB Ram, RTX3080 but my GPU doesn't have video output sync. Sometimes I use my machine with led wall and I need output SYNC. Now I have the opportunity to change RTX3080 for RTX5000. Will the rtx50000 quadro work well with VMIX? Please help because I don't know what to do I second what timmy said. the RTX Quadro line work awesome, and the new Ampere line should work even better with its added memory and pipeline increases. I only use quadro's due to the flexibility (the added settings and card config) , stability, and unrestricted encoding. plus the rtx 5000 has two decode chips.
