[SOLVED] Start a Picture Sequence from a specific point
This is my question...
Is it possible, using triggers, to start a picture sequence from a specific photo?
I have a single folder with photos. I need to play them many times starting from a different position each time. Is it possible to do it using the same picture's folder without creating a set of folders (one for each cue)?
I can't find anything useful inside the trigger list.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
what do you want to trigger on ? how are you going to decide which position to start from ? check the SelectIndex shortcut  selectindex.JPG (43kb) downloaded 0 time(s).
Hi, it doesn't work. But thanks for the suggestion.
I need to play a set of pictures, many times in the same stream. But, each time I have to start from a different picture, whose position is known from the beginning. So, What I think to do is...
starting from the same picture's folder I go to create different cues in the show. Each cue is referring to the same folder. What I need to do is to tell to vmix from which picture start each time I recall a different cue of these Photos. So, the first time I have to start from the very beginning, and this is easy. The second time I have to start from the 4th, than the 8th, 10th,.....
I'm not using a virtual set, just playing these fullscreen.
I already tryed using:
SetPosition ... but it works in milliseconds not in relative position. No effect on Pictures StartPlayList ... nothing AutoPlayFirst ... nothing Next Picture ... just move to the second picture NextPlayListEntry ... no effect SetImage ... no effect
I don't really know what to do more. Or even if it is possible to do it someway.
SelectIndex
this is the right function to start from a specific position.
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
In vMix 24, you might also want to consider using Dynamic values to set the index number...
