Joined: 1/14/2014(UTC) Posts: 7 Location: The Netherlands (Europe)
On a website we like to transmit there is the next code:
<param name="wmode" value="transparent" /> <param name="movie" value="http://www.raad-achtkarspelen.nl/flash/player.swf" /> <param name="allowscriptaccess" value="always" /> <param name="allowfullscreen" value="true" /> <param name="flashvars" value="file=livestream&autostart=true&streamer=rtmp://go-fms01v.gemeenteoplossingen.nl/rd-mp4/achtkarspelen_3&plugins=gapro-1&gapro.accountid=UA-26108244-1" />
I have tried many things, but couldn't get the right stream. Wahtever i tried in this string rtmp://go-fms01v.gemeenteoplossingen.nl/rd-mp4/achtkarspelen_3&plugins=gapro-1&gapro.accountid=UA-26108244-1 i always get a media playback error
I know this is not vMIX related, but can someone point this out for me?
Thanks in advance,
marcel
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
Hi dotinga00,
The following format usually works for me:
RTMP-URL/Streamname
E.G rtmp://mystreamingCDN/myStreamname, as taken from encoder settings (FMLE).
Your mileage might vary.
Maxi
Joined: 4/9/2014(UTC) Views messages in topic : 110 Location: USA
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
what service are you using to stream?
the above doesn't look correct.
it should look like this, depending on your provider: <script type="text/javascript" src="http://DOMAINTOJAVASCRIPTPLAYER.com/swfobject.js"></script> <div id="player">Name of Event</div> <script type="text/javascript"> var so = new SWFObject('http://DOMAINTOPLAYER.com/player.swf','mpl','480','290','9'); so.addParam('allowscriptaccess','always'); so.addParam('allowfullscreen','true'); so.addParam('type', 'video'); so.addVariable('skin', 'stylish.swf'); so.addParam('flashvars','&streamer=rtmp://URLOFSTREAMER/vod&file=YOURFILENAME.mp4&autostart=true'); so.write('player'); </script>
vod can also be replaced by live if you are live, then you leave off the file extension .mp4
