dotinga00
#1 Posted : Thursday, April 17, 2014 2:07:03 PM(UTC)
dotinga00
On a website we like to transmit there is the next code:
<param name="wmode" value="transparent" />
<param name="movie" value="http://www.raad-achtkarspelen.nl/flash/player.swf" />
<param name="allowscriptaccess" value="always" />
<param name="allowfullscreen" value="true" />
<param name="flashvars" value="file=livestream&amp;autostart=true&amp;streamer=rtmp://go-fms01v.gemeenteoplossingen.nl/rd-mp4/achtkarspelen_3&amp;plugins=gapro-1&amp;gapro.accountid=UA-26108244-1" />
I have tried many things, but couldn't get the right stream. Wahtever i tried in this string rtmp://go-fms01v.gemeenteoplossingen.nl/rd-mp4/achtkarspelen_3&amp;plugins=gapro-1&amp;gapro.accountid=UA-26108244-1 i always get a media playback error
I know this is not vMIX related, but can someone point this out for me?
Thanks in advance,
marcel
Maximus
#2 Posted : Monday, April 21, 2014 2:20:41 PM(UTC)
Maximus
Hi dotinga00,
The following format usually works for me:
RTMP-URL/Streamname
E.G
rtmp://mystreamingCDN/myStreamname, as taken from encoder settings (FMLE).
Your mileage might vary.
Maxi
coskel22
#3 Posted : Monday, April 21, 2014 6:43:38 PM(UTC)
coskel22
what service are you using to stream?
the above doesn't look correct.
it should look like this, depending on your provider:
<script type="text/javascript" src="http://DOMAINTOJAVASCRIPTPLAYER.com/swfobject.js"></script>
<div id="player">Name of Event</div>
<script type="text/javascript">
var so = new SWFObject('http://DOMAINTOPLAYER.com/player.swf','mpl','480','290','9');
so.addParam('allowscriptaccess','always');
so.addParam('allowfullscreen','true');
so.addParam('type', 'video');
so.addVariable('skin', 'stylish.swf');
so.addParam('flashvars','&streamer=rtmp://URLOFSTREAMER/vod&file=YOURFILENAME.mp4&autostart=true');
so.write('player');
</script>
vod can also be replaced by live if you are live, then you leave off the file extension .mp4
