Vmix for some reason crashes with the Zoom Livetrak L-8. When trying to pipe individual audio channels into Vmix using the ASIO driver, it crashes when you add the 2nd pair. IE in 1 + 2 imports, then when you add in 3 + 4 Vmix locks up and doesn't respond.
I am having the same issue. Was there ever a solution for this?
Joined: 11/17/2020(UTC) Views messages in topic : 1  Location: Orléans
Hi, I am interested in this product, were you able to fix this problem? Thanks in advance
Thanks: 187 times Was thanked: 20 time(s) in 17 post(s)
It does work, You will need to make get the driver from the zoom website and use the ZOOM L-8 ASIO driver. Overall we like this recorder my only complaint would be it takes 3 buttons to get it to record which is easy to miss.
 1 user thanked bonesaw207 for this useful post.
Thanks lots. Mine just arrived and indeed, installed the Windows driver, selected its Asio in vMix (v23 in my case), and then you're able to select the individual channels as separate audio inputs in vMix. Just what I needed.
Thanks again for your help.
