goaliebob99
#1 Posted : Thursday, March 19, 2020 1:55:19 PM(UTC)
goaliebob99
Vmix for some reason crashes with the Zoom Livetrak L-8. When trying to pipe individual audio channels into Vmix using the ASIO driver, it crashes when you add the 2nd pair. IE in 1 + 2 imports, then when you add in 3 + 4 Vmix locks up and doesn't respond.
bonesaw
#2 Posted : Thursday, November 5, 2020 1:22:04 AM(UTC)
bonesaw
I am having the same issue. Was there ever a solution for this?
florentbyflo
#3 Posted : Tuesday, November 17, 2020 2:42:32 AM(UTC)
florentbyflo
I am interested in this product, were you able to fix this problem?
Thanks in advance
Ario
#4 Posted : Friday, March 26, 2021 5:38:52 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Looking at this mixer as well. Can anyone confirm that adding the various individual channels to vMix DOES (not?) work?
Thanks so much.
PS: on https://forums.vmix.com/posts/t16055-ZOOM-LIVETRACK-L-12 it seems that the L-12 model DOES work with vMix.
bonesaw207
#5 Posted : Friday, March 26, 2021 6:30:05 AM(UTC)
bonesaw207
It does work, You will need to make get the driver from the zoom website and use the ZOOM L-8 ASIO driver. Overall we like this recorder my only complaint would be it takes 3 buttons to get it to record which is easy to miss.
thanks 1 user thanked bonesaw207 for this useful post.
Ario on 3/26/2021(UTC)
Ario
#6 Posted : Friday, March 26, 2021 9:16:41 PM(UTC)
Ario
Thanks lots. Mine just arrived and indeed, installed the Windows driver, selected its Asio in vMix (v23 in my case),
and then you're able to select the individual channels as separate audio inputs in vMix. Just what I needed.
Thanks again for your help.
Similar Topics
zoom livetrak L-8 VMIX compatibility (Hardware Compatibility)
by jaialai 6/17/2024 4:32:07 AM(UTC)
Zoom Livetrak L-8 with VMIX. (Hardware Compatibility)
by jaialai 6/7/2024 4:59:38 AM(UTC)
