Chris Daum
#1 Posted : Monday, March 22, 2021 11:10:06 PM(UTC)
Chris Daum
Germany
Hi Champs,
I have a (one might consider stupid or beginner) question.
I did a research in Vmix manual in this forum but couldn´t find
a proper answer.
What exactly means "Dynamic Input"?
What can be done with them in comparison to a regular input?
I really do a lot with and in Vmix and for that quite a major
amount of research.
But I could´nt find anything useful concerning that issue...
dmwkr
#2 Posted : Tuesday, March 23, 2021 12:56:57 AM(UTC)
dmwkr
thanks 1 user thanked dmwkr for this useful post.
Chris Daum on 3/23/2021(UTC)
#3 Posted : Tuesday, March 23, 2021 1:05:27 AM(UTC)
They are a sort of variable
Maybe this is the most simple way to explain how one can use them
Code:
API.Function("SetDynamicInput1",Value:="SomeTitle.gtzip") or API.Function("SetDynamicInput1",Value:="37")
API.Function("SetDynamicValue1",Value:="Guest Name")
API.Function("SetText",Input:="Dynamic1",SelectedName:="Description.Text",Value:="Dynamic1")
'becomes same as
API.Function("SetText",Input:="SomeTitle.gtzip",SelectedName:="Description.Text",Value:="Guest Name")
Note that to use them be it as Input or Value they both have to be called with DynamicX in your function or shortcut, based on if they are used as Input or Value they will retrieved as set with SetdynamicInput or SetDynamicValue
https://forums.vmix.com/...ng-for-Dummies#post88552
thanks 2 users thanked doggy for this useful post.
dmwkr on 3/23/2021(UTC), Chris Daum on 3/23/2021(UTC)
