Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
Hi Champs,
I have a (one might consider stupid or beginner) question. I did a research in Vmix manual in this forum but couldn´t find a proper answer.
What exactly means "Dynamic Input"? What can be done with them in comparison to a regular input?
I really do a lot with and in Vmix and for that quite a major amount of research. But I could´nt find anything useful concerning that issue...
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
 1 user thanked dmwkr for this useful post.
They are a sort of variable Maybe this is the most simple way to explain how one can use them Code:API.Function("SetDynamicInput1",Value:="SomeTitle.gtzip") or API.Function("SetDynamicInput1",Value:="37")
API.Function("SetDynamicValue1",Value:="Guest Name")
API.Function("SetText",Input:="Dynamic1",SelectedName:="Description.Text",Value:="Dynamic1")
'becomes same as
API.Function("SetText",Input:="SomeTitle.gtzip",SelectedName:="Description.Text",Value:="Guest Name")
Note that to use them be it as Input or Value they both have to be called with DynamicX in your function or shortcut, based on if they are used as Input or Value they will retrieved as set with SetdynamicInput or SetDynamicValue https://forums.vmix.com/...ng-for-Dummies#post88552
 2 users thanked doggy for this useful post.
