melody
#1 Posted : Monday, September 26, 2011 3:26:56 PM(UTC)
Rank: Guest
Groups: Guests
hi martin,
i just finished the recording of sunday afternoon service, at my church, and no sound was recorded in mpg file. here goes the screen...
http://imageshack.us/pho...peg2recordingnosound.png
hope it can be fixed, regards...
melody
www.espiritosanto.cc
#2 Posted : Monday, September 26, 2011 11:31:26 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Please make sure you have selected an audio source in the recording setup window.
I have tested this and the audio is working...
melody
#3 Posted : Tuesday, September 27, 2011 11:01:04 AM(UTC)
Rank: Guest
Groups: Guests
yes, i selected the correct audio device input.
now think better, isn´t the problem on select the same audio input used in the flash encoder?
#4 Posted : Wednesday, September 28, 2011 12:04:21 AM(UTC)
Yes, most sound cards only support selecting an audio device input once.
If you want more, you could try something like the Virtual Audio Cable.
melody
#5 Posted : Wednesday, September 28, 2011 6:12:49 AM(UTC)
Rank: Guest
Groups: Guests
thats ok, i`ll try a diferent sound device input to record.
thank you for support.
regards,
melody
melody
#6 Posted : Wednesday, October 5, 2011 5:13:37 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
mpeg2 still recording with no sound... can you take a look?
regards,
melody
#7 Posted : Wednesday, October 5, 2011 5:17:26 AM(UTC)
Hi Melody,
As mentioned it has been tested and is working.
You will need to make sure the device used when setting up the recording is not used by any other programs.
(Note that this is a per-device, not a per input limitation, For example you cannot record both from the Stereo Mix and the Line Input at the same time with many built in sound cards.)
melody
#8 Posted : Wednesday, October 5, 2011 5:43:24 AM(UTC)
Rank: Guest
Groups: Guests
i tested to record in *.avi using lagarith and the sound was recorded sucessfull with the same device selected to record with *.mpg
last recording, i used the audio input device from pixelview play tv xtreme (http://www.pixelview.com.br/placa_pixelview_playtv_xtreme.asp) and mpeg-2 still doesn`t recorded the sound.
however, as i said before, i am recording the sound to a second pc. my audio mixer is peavey 32fx and it have usb support to record audio from. i will try to test another options here to see if i can find a solution.
regards,
melody
#9 Posted : Wednesday, October 5, 2011 5:48:18 AM(UTC)
Hi Melody,
Could you post a screenshot of the settings used in the MPEG-2 Recording Setup window?
Thanks,
melody
#10 Posted : Wednesday, October 5, 2011 5:54:23 AM(UTC)
Rank: Guest
Groups: Guests
yes, for sure... click link below.
http://imageshack.us/pho...s/442/mpeg2settings.jpg/
melody
update: here goes the settings with diferent audio device mentioned before.
http://imageshack.us/pho.../522/mpeg2settings2.jpg/
#11 Posted : Wednesday, October 5, 2011 7:14:45 AM(UTC)
Try selecting 44100 Hz as the Audio Format
melody
#12 Posted : Wednesday, October 5, 2011 7:44:27 AM(UTC)
Rank: Guest
Groups: Guests
tested and woking... problem solved.
maybe would be good idea to disable 96000khz at mpeg-2 recording to avoid audio problems, that was my problem...
thank you martin for support.
update: 44100hz and 48000hz working fine.
