Jose Barbosa
#1 Posted : Thursday, March 18, 2021 10:01:41 AM(UTC)
Jose Barbosa
Portugal
First of all I'm new in VMIX.
It is possible to do a transition between two inputs like this link. This example it was made in a tricaster NDI 4k (see after the time 38:17)
?t=2297
In one input it's a talking head doing a presentention. In the other input it's a power point via ndi. If the size of an input increase the size of the other input decrease proportionally.
Thank´s
SuperBill
#2 Posted : Thursday, March 18, 2021 1:13:21 PM(UTC)
SuperBill
Canada
Probably by using a virtual input and merge transition, but you have to know your start and end sizes, doing it on the fly would be tricky, or require a small script.
check out the vmix squerge video for some insights:
thanks 1 user thanked SuperBill for this useful post.
Jose Barbosa on 3/19/2021(UTC)
#3 Posted : Thursday, March 18, 2021 5:32:47 PM(UTC)
No Need for any script at all !
Transition to a multiview and then Merge to another multiview containing the same inputs with a different position layout (called preparation )
