Transition between two inputs
Joined: 2/8/2021(UTC) Posts: 4  Location: Lisboa Thanks: 3 times
First of all I'm new in VMIX. It is possible to do a transition between two inputs like this link. This example it was made in a tricaster NDI 4k (see after the time 38:17) ?t=2297 In one input it's a talking head doing a presentention. In the other input it's a power point via ndi. If the size of an input increase the size of the other input decrease proportionally. Thank´s
Joined: 2/5/2021(UTC) Posts: 38  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Probably by using a virtual input and merge transition, but you have to know your start and end sizes, doing it on the fly would be tricky, or require a small script. check out the vmix squerge video for some insights:
 1 user thanked SuperBill for this useful post.
Originally Posted by: SuperBill  doing it on the fly would be tricky, or require a small script.
No Need for any script at all ! Transition to a multiview and then Merge to another multiview containing the same inputs with a different position layout (called preparation )
