matkeane
#1 Posted : Wednesday, March 17, 2021 8:26:54 PM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
I've been using vMix Call to bring remote guests into productions but, almost inevitably, some guests and clients are now asking whether it's possible to do automatic background removal/replacement in the same way that Zoom/Teams/etc offer. I realise that I could just use Zoom/Teams/etc instead, but vMix Call integrates nicely into productions, so I've been searching online to see what third-party tools exist to do the background removal...
I found a couple of posts where people are trying to use TouchDesigner to do face tracking/edge detection to do something similar, but it's little but too DIY for me.
I found another app - https://manycam.com/ - which supports multiple NDI inputs and generates an NDI output, so would be nice and easy to integrate with vMix, but the results aren't as good as I was hoping (very noisy edges, few frames of delay).
So, I was wondering whether the vMix community have any tips for other tried/tested/rejected solutions out there - I'm grateful for any suggestions!
Thanks,
Matthew
Aecast
#2 Posted : Friday, March 19, 2021 11:10:44 AM(UTC)
Aecast
Was thanked: 10 time(s) in 7 post(s)
Hi Matthew,
I have been using xsplit cam which works well and fairly clean edges but does depend on the quality of your feed into it.
I have taken Vmix Calls out as vmix camera feed or use NDI with newtek ndi input tools, the xsplit cam output can then be brought back into vmix as a camera video input.
matkeane
#3 Posted : Friday, March 19, 2021 4:30:20 PM(UTC)
matkeane
Thanks for the recommendation - I will check that out.
HypeCats
#4 Posted : Sunday, May 2, 2021 3:48:49 AM(UTC)
HypeCats
https://obs.ninja just added greenscreen and blur. Haven't tested it with a good camera yet but it looked promising.
Vemmnaule
#5 Posted : Monday, June 6, 2022 2:46:11 PM(UTC)
Vemmnaule
Philippines
You can check out Snapcamera its an awesome app works just as Snap app for mobile phones
Guest (4)
