Hardware Compatibility
Wrong inputs displayed for audio interface
I have two different usb audio interfaces connected to my Vmix computer. One is an older Tascam US-2000, and the other is a MOTU M2. I am generally using the M2 for my microphone input on channel one. When I go to the "add input" function to add an audio input, in the "audio device" dropdown, both units are listed (as one would expect). When I select the "MOTU M Series", I am greeted with the 24 inputs of the Tascam US-2000. The opposite is also true, whereby when I select the US-2000, I am offered the availability of the 9 inputs from the M2. Now here's the fun part, when I SELECT either of the first two inputs from the Motu M series dropdown (which consists of the 24 US2000 inputs), I get my appropriate M2 microphone input. It seems that somehow the input lists for the two interfaces are switched in the dropdown. Any ideas how to remedy this?
Originally Posted by: boburtz  I have two different usb audio interfaces connected to my Vmix computer. One is an older Tascam US-2000, and the other is a MOTU M2. I am generally using the M2 for my microphone input on channel one. When I go to the "add input" function to add an audio input, in the "audio device" dropdown, both units are listed (as one would expect). When I select the "MOTU M Series", I am greeted with the 24 inputs of the Tascam US-2000. The opposite is also true, whereby when I select the US-2000, I am offered the availability of the 9 inputs from the M2. Now here's the fun part, when I SELECT either of the first two inputs from the Motu M series dropdown (which consists of the 24 US2000 inputs), I get my appropriate M2 microphone input. It seems that somehow the input lists for the two interfaces are switched in the dropdown. Any ideas how to remedy this? UPDATE: It seems an update to the VMix software fixed the issue...
