Martinius
#1 Posted : Friday, March 12, 2021 1:39:28 AM(UTC)
Martinius
Austria
I wonder if it is possible to set a shortcut the show a certain PTZ Camera Preset - not Camera HOME.
lets say cam 1 is on close up of Gitare Player.. In PTZOptics Control it would be Preset 3 on cam 2
Is it possible to do that...
I know i can with companion, but is it with vmix?
#2 Posted : Friday, March 12, 2021 1:57:08 AM(UTC)
Don't the presets created become (PTZ) inputs , so selecting the input with a shortcut ?
See helpfiles
Martinius
#3 Posted : Monday, March 15, 2021 7:33:20 PM(UTC)
Martinius
Austria
See helpfiles
No,
It is just Cam 1 and Cam 2 (in our case... we only have 2 Cams)
> as we have PTZ Cams we have 12+ Presets.
In order to make it easy to use for volunteers, I would like to have
Buttons on a Elgato STream Deck to push and show the selected preset position of the cameras...
dmwkr
#4 Posted : Tuesday, March 16, 2021 2:50:16 AM(UTC)
dmwkr
Basically, you create your PTZ presets IN vMix, not in the the camera software. Maybe you want to take a look at the PTZ options of vMix, as doggy suggested, in the helpfiles or in videos like these:
Martinius
#5 Posted : Tuesday, March 16, 2021 3:27:50 AM(UTC)
Martinius
Austria
Ah ok...
So it is only possible with 4K and Pro Lizens?
Korrekt?
Martinius
#6 Posted : Tuesday, March 16, 2021 3:54:01 AM(UTC)
Martinius
Austria
So if not with 4K oder Pro Version - work with companion / Stream Deck setups...
