PTZ Preset as shortcut to fire with stream deck
Joined: 2/21/2021(UTC) Posts: 15  Location: Tirol Thanks: 1 times
Hi, I wonder if it is possible to set a shortcut the show a certain PTZ Camera Preset - not Camera HOME. lets say cam 1 is on close up of Gitare Player.. In PTZOptics Control it would be Preset 3 on cam 2
Is it possible to do that... I know i can with companion, but is it with vmix?
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Don't the presets created become (PTZ) inputs , so selecting the input with a shortcut ?
See helpfiles
Originally Posted by: doggy  Don't the presets created become (PTZ) inputs , so selecting the input with a shortcut ?
See helpfiles No, It is just Cam 1 and Cam 2 (in our case... we only have 2 Cams) > as we have PTZ Cams we have 12+ Presets. In order to make it easy to use for volunteers, I would like to have Buttons on a Elgato STream Deck to push and show the selected preset position of the cameras...
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Basically, you create your PTZ presets IN vMix, not in the the camera software. Maybe you want to take a look at the PTZ options of vMix, as doggy suggested, in the helpfiles or in videos like these:
Originally Posted by: dmwkr  Basically, you create your PTZ presets IN vMix, not in the the camera software. Maybe you want to take a look at the PTZ options of vMix, as doggy suggested, in the helpfiles or in videos like these: Ah ok... So it is only possible with 4K and Pro Lizens? Korrekt?
Originally Posted by: dmwkr  Basically, you create your PTZ presets IN vMix, not in the the camera software. Maybe you want to take a look at the PTZ options of vMix, as doggy suggested, in the helpfiles or in videos like these: So if not with 4K oder Pro Version - work with companion / Stream Deck setups...
