Rinsky
#1 Posted : Tuesday, April 15, 2014 2:02:23 PM(UTC)
Rinsky
is it possible to stream external 1 (let's say input1 with 720p) live and record external 2 (input 2 with 1080p) on 1 machine, without using an external recorder?
I only manage to stream and record the same input, how can i change that?
dotinga00
#2 Posted : Wednesday, April 16, 2014 11:02:37 AM(UTC)
dotinga00
Had the same problem, solved it by using two user accounts and running two instances of vMIX. If there is an easier way i'd like to here it too ;-)
marcel
