Streaming and recording different outputs
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
is it possible to stream external 1 (let's say input1 with 720p) live and record external 2 (input 2 with 1080p) on 1 machine, without using an external recorder?
I only manage to stream and record the same input, how can i change that?
Joined: 1/14/2014(UTC) Posts: 7 Location: The Netherlands (Europe)
Rinsky wrote:Hi,
I only manage to stream and record the same input, how can i change that? Had the same problem, solved it by using two user accounts and running two instances of vMIX. If there is an easier way i'd like to here it too ;-) Regards, marcel
