abtaster
#1 Posted: : Wednesday, March 10, 2021 12:27:06 AM(UTC)
abtaster
I am testing Vmix 24 for the first time and converting my Vmix 23 presets.
When a Replay is played and I want to set a new mark (eg -10) replay stop and cuts to preview.
anybody else having this problem or is it just a ?
Henrik
#2 Posted : Wednesday, March 10, 2021 3:10:40 AM(UTC)
This is by design, any editing of events will naturally stop any playing back events as it needs to switch to that new event to show the previews.
You can use the new separate channels feature (edit on A while playing back on B) if you do not want them changing each other.
abtaster
#3 Posted : Wednesday, March 10, 2021 7:42:20 AM(UTC)
abtaster
Hi Martin,
thanks for the fast reply.
This is new, isn't it?
In my case, I do all with shortcuts:
ReplayMarkInOut 8/10/20/60 Sec.
Playout:
ReplaySelectLastEvent
ReplaySelectEventSingleCamera (1...4 or now 8)
ReplayPlayLastEventToOutput
No editing, just as is. If a replay is shown anything can happen on the field, that needs a review.
Is there any way to get this now done with shortcuts or triggers? (Like "Move to Replay B") The amount of buttons is limited.
Many Thanks and stay safe
Henrik
abtaster
#4 Posted : Thursday, March 11, 2021 12:40:00 AM(UTC)
abtaster
Finally I made it work! Maybe not the way it should, but here my solution:
Channel B for mark in an out
Shortcuts:
"ReplaySelectChannelB" & "ReplayMarkInOutLive (Value x in seconds)" mapped to button 1
Channel A for Playback
"ReplaySelectChannelA" & "ReplaySelectLastEvent (Play Channel A)" & "ReplaySelectedEventSingleCameraOn (Value camera number)" & PraplayPlayLastEventToOutput (Play Channel A) mapped to button 2
To change the camera during replay
"ReplayACamera1...8" & "ReplayBCamera1...8" mapped to button 3..10
Good Luck!
ralston
#5 Posted : Saturday, March 13, 2021 5:12:58 AM(UTC)
ralston
I have found none of my stream deck short cuts now work with the new 24 replay. -5 , -7 , -10 etc can't mark IN /OUT - can't go to Air ... have remapped just incase the links had been broken but still doesn't seem to work. Not sure what I am doing wrong. Game tomorrow ! whoops
abtaster
#6 Posted : Saturday, March 13, 2021 7:04:11 AM(UTC)
abtaster
It seems that there is a new shortcut
use "ReplayMarkInOutLive" instead of "ReplayMarkInOut"
