Instant Replay
Bug? replay playout end when new mark in/out is set
I am testing Vmix 24 for the first time and converting my Vmix 23 presets. When a Replay is played and I want to set a new mark (eg -10) replay stop and cuts to preview. anybody else having this problem or is it just a ?
Thanks Henrik
Joined: 1/13/2010(UTC) Posts: 5,375  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
This is by design, any editing of events will naturally stop any playing back events as it needs to switch to that new event to show the previews. You can use the new separate channels feature (edit on A while playing back on B) if you do not want them changing each other.
Martin vMix
Hi Martin,
thanks for the fast reply.
This is new, isn't it?
In my case, I do all with shortcuts: ReplayMarkInOut 8/10/20/60 Sec.
Playout: ReplaySelectLastEvent ReplaySelectEventSingleCamera (1...4 or now 8) ReplayPlayLastEventToOutput
No editing, just as is. If a replay is shown anything can happen on the field, that needs a review. Is there any way to get this now done with shortcuts or triggers? (Like "Move to Replay B") The amount of buttons is limited.
Many Thanks and stay safe Henrik
Finally I made it work! Maybe not the way it should, but here my solution:
Channel B for mark in an out Shortcuts: "ReplaySelectChannelB" & "ReplayMarkInOutLive (Value x in seconds)" mapped to button 1
Channel A for Playback "ReplaySelectChannelA" & "ReplaySelectLastEvent (Play Channel A)" & "ReplaySelectedEventSingleCameraOn (Value camera number)" & PraplayPlayLastEventToOutput (Play Channel A) mapped to button 2
To change the camera during replay "ReplayACamera1...8" & "ReplayBCamera1...8" mapped to button 3..10
Good Luck!
Joined: 10/10/2019(UTC) Posts: 52  Location: london Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
I have found none of my stream deck short cuts now work with the new 24 replay. -5 , -7 , -10 etc can't mark IN /OUT - can't go to Air ... have remapped just incase the links had been broken but still doesn't seem to work. Not sure what I am doing wrong. Game tomorrow ! whoops
Originally Posted by: ralston  I have found none of my stream deck short cuts now work with the new 24 replay. -5 , -7 , -10 etc can't mark IN /OUT - can't go to Air ... have remapped just incase the links had been broken but still doesn't seem to work. Not sure what I am doing wrong. Game tomorrow ! whoops It seems that there is a new shortcut use "ReplayMarkInOutLive" instead of "ReplayMarkInOut"
Instant Replay
