Joined: 3/5/2021(UTC) Posts: 1  Location: quebec Thanks: 1 times
Hi there! Have got vmix and zoom on the same computer, using virtual cable A and B. A=Microphone and B=Speaker. OK that’s works! But if I have 4 more zoom laptop, can I use virtual cable C and D to send them a different mix. I want to be able to talk at my main zoom (Vmix pc) by bus A but not to the other 4. Is that possible?
Joined: 12/14/2018(UTC) Posts: 88  Was thanked: 18 time(s) in 7 post(s)
If I am not wrong, I believe that if you use NDI to send and receive Zooms over a different computers it will do MixMinus by default. So you can send one bus to all computers and it will return sound without that bus. Am I wrong?
Since you know VBaudio, check VBAN which is an audio over IP protocol (like NDI but just for audio) With VBAN you can transport up to 8 feeds over your network. Meaning along with VB cables you can send and use vMix busses on remote computers.
Joined: 6/18/2020(UTC) Posts: 26   Location: Manila Thanks: 57 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: Claude  Hi there! Have got vmix and zoom on the same computer, using virtual cable A and B. A=Microphone and B=Speaker. OK that’s works! But if I have 4 more zoom laptop, can I use virtual cable C and D to send them a different mix. I want to be able to talk at my main zoom (Vmix pc) by bus A but not to the other 4. Is that possible? Yes, it could be... but NDI is a easier way.
