Claude
#1 Posted : Sunday, March 7, 2021 9:08:24 AM(UTC)
Claude
Canada
Hi there!
Have got vmix and zoom on the same computer, using virtual cable A and B. A=Microphone and B=Speaker.
OK that’s works!
But if I have 4 more zoom laptop, can I use virtual cable C and D to send them a different mix. I want to be able to talk at my main zoom (Vmix pc) by bus A but not to the other 4.
Is that possible?
gre2gor
#2 Posted : Sunday, March 7, 2021 2:53:05 PM(UTC)
gre2gor
Slovenia
Was thanked: 18 time(s) in 7 post(s)
If I am not wrong, I believe that if you use NDI to send and receive Zooms over a different computers it will do MixMinus by default. So you can send one bus to all computers and it will return sound without that bus. Am I wrong?
#3 Posted : Sunday, March 7, 2021 5:53:58 PM(UTC)
Since you know VBaudio, check VBAN which is an audio over IP protocol (like NDI but just for audio)
With VBAN you can transport up to 8 feeds over your network. Meaning along with VB cables you can send and use vMix busses on remote computers.
Claude on 3/8/2021(UTC)
Roi
#4 Posted : Monday, March 8, 2021 2:22:22 AM(UTC)
Roi
Philippines
Originally Posted by: Claude Go to Quoted Post
Hi there!
OK that’s works!
Is that possible?
Yes, it could be... but NDI is a easier way.
