GT
animate text on / off via data source (heart monitor)
Rank:: Member
Joined: 11/14/2012(UTC) Posts: 10 Location: Los Angeles
I have the following Title designed.
A text box with a number and a text box with a icon looking like a heart.
Can I animate the visibility of the text field via script based on a data source?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
why script , use the data source : one row blank , next row your data and loop
Rank:: Member
Made a CSV file with 2 rows. Where can i loop the data source?
Found the settings the lowest value i can add is 1 sec
The visibility should correspond with the heartrate number so thats a no go.
Problem is i need to update this value dynamically based on the value of the heart rate.
Originally Posted by: hive8  Made a CSV file with 2 rows. Where can i loop the data source?
Problem is i need to update this value dynamically based on the value of the heart rate. Now we are getting more details in what you want to achieve ;-) While matching the value might be not exact a script is indeed the way to go have loop in a script turning the displaying on/off (SetTextVisible) with a pause in between with delay based on the data
Rank:: Member
Could you provide a little example. Just trying to wrap my head around it.
Originally Posted by: hive8  Could you provide a little example. Just trying to wrap my head around it. You mean give you the script ? in a continuous loop read the heartbeat value from the title (*) convert it to a numeric value do a little test to check if between a range and if value has changed (matter of a bit more efficientand cleaner display later) to make it look like a beat show the text or any other title element to depict the beating by turning its visibility on Pause for a short bit Hide the element Pause for the heartbeat duration minus the previous pause (looks better then twice half the beat duration) repeat (*) check the "scripting for dummies" post in this forum Check the helpfiles for the visibility functions (shortcut list)
GT
