hive8
#1 Posted : Friday, March 5, 2021 5:25:09 PM(UTC)
hive8
I have the following Title designed.
A text box with a number and a text box with a icon looking like a heart.
Can I animate the visibility of the text field via script based on a data source?
#2 Posted : Friday, March 5, 2021 6:11:43 PM(UTC)
why script , use the data source : one row blank , next row your data and loop
hive8
#3 Posted : Friday, March 5, 2021 6:22:44 PM(UTC)
hive8
Made a CSV file with 2 rows. Where can i loop the data source?
Found the settings the lowest value i can add is 1 sec
The visibility should correspond with the heartrate number so thats a no go.
Problem is i need to update this value dynamically based on the value of the heart rate.
#4 Posted : Friday, March 5, 2021 7:03:42 PM(UTC)
Now we are getting more details in what you want to achieve ;-)
While matching the value might be not exact a script is indeed the way to go
have loop in a script turning the displaying on/off (SetTextVisible) with a pause in between with delay based on the data
hive8
#5 Posted : Tuesday, March 9, 2021 1:49:39 PM(UTC)
hive8
Could you provide a little example. Just trying to wrap my head around it.
#6 Posted : Tuesday, March 9, 2021 7:02:51 PM(UTC)
You mean give you the script ?
in a continuous loop read the heartbeat value from the title (*)
convert it to a numeric value
do a little test to check if between a range and if value has changed (matter of a bit more efficientand cleaner display later)
to make it look like a beat show the text or any other title element to depict the beating by turning its visibility on
Pause for a short bit
Hide the element
Pause for the heartbeat duration minus the previous pause (looks better then twice half the beat duration)
repeat
(*) check the "scripting for dummies" post in this forum
Check the helpfiles for the visibility functions (shortcut list)
