GT
Mis matched Data source input from source cell
Hey vMix, I've been setting up a ticker title that worked for the month of February as intended. I went to update my spreadsheet for March and now I have a couple of cells that do not seem to be updating on the vmix side. No idea what the issue is as it is picking up other cell changes. Image reference here: https://imgur.com/a/ITVKdu4Any idea what is going on?
Try saving the file again , or reload it for your data source , where is the source file located ?
Originally Posted by: doggy  Try saving the file again , or reload it for your data source , where is the source file located ? Honored to have your response, doggy. Your input across these forums has already helped me tons. I've tried the above. Data source is google sheets. The blank cells are just for spacing & the February fields were simply replaced with the March fields. The YTD fields stayed the same. I'm going to try to put the ticker info in its own sheet since I have the formula references off to the right at the moment.
GT
