BriceMunn
#1 Posted : Wednesday, February 24, 2021 11:17:56 PM(UTC)
BriceMunn
I keep finding myself in situations where multiple 3.5mm audio inputs/outputs are needed to route different busses to. Can anyone recommend a USB device which can handle 4 or 5 audio inputs and outputs? So I can map several audio buses to it and equally add several audio inputs from it?
Kind of like this: https://www.amazon.co.uk...ws-AU-MMSA/dp/B00IRVQ0F8
But with multiple ins/outs. The key is that I do not need a splitter/signal duplicator - I need to assign a separate vMix audio bus to each port.
Is this even technically possible?
#2 Posted : Thursday, February 25, 2021 3:34:54 AM(UTC)
Rank:: Advanced Member
I use the MIDAS MR18 console to do this.
It has 18 inputs which can be either XLR or USB and 6 AUX which also can be used via XLR or USB.
Perfect solution to handle ins and outs with vMix.
A slightly cheaper model is the Behringer XR18 which has the exact same features but cheaper preamps and connectors.
BriceMunn
#3 Posted : Thursday, February 25, 2021 3:58:51 AM(UTC)
BriceMunn
Interesting, thank you. Sorry, I am completely new to a lot of this, forgive the silly question- when connected over USB do the MR18 outputs show up as multiple selectable devices (so different sound buses can run to them)?
richardgatarski
#4 Posted : Thursday, February 25, 2021 5:40:30 AM(UTC)
richardgatarski
yes, 16 in and 16 out (given you install Behringer's USB driver ASIO)
BriceMunn on 2/25/2021(UTC)
#5 Posted : Thursday, February 25, 2021 5:41:57 AM(UTC)
The usb connection exposes each channel from the console as inputs or outputs (in audio settings)
So you can input any channel or aux or main mix or a combination of them in vMix
And you can configure any of the vMix busses + master and phones outputs to any input in the console.
16 in and 16 out
18 actually, 16 mono + 1 stereo
BriceMunn
#6 Posted : Thursday, February 25, 2021 7:03:59 PM(UTC)
BriceMunn
I see, thank you. This sounds perfect!
3xscreen
#7 Posted : Tuesday, March 2, 2021 9:41:05 PM(UTC)
3xscreen
We use the FocusRite Scarlett 18i20 (3rd Gen) for this use case. Works well for simultaneous in and outs - except we are seeing something a little weird which I suspect is linked to the FocusRite and that is that audio delays seem to drift around by up to a few frames. I've never seen drifting audio sync before.
SethJames9000
#8 Posted : Friday, March 5, 2021 4:06:05 AM(UTC)
SethJames9000
Hi, Just wanted to chime in here. I am attempting to use M Audio air 192 8 and the result is terrible. Are you guys getting clicks and pops with your usb interface?
richardgatarski
#9 Posted : Friday, March 5, 2021 5:04:21 AM(UTC)
richardgatarski
