recover via script the preview source
Joined: 1/29/2021(UTC) Posts: 16  Location: valencia Thanks: 2 times
hello,
Why this not works.
Dim doc as new XmlDocument() doc.LoadXml(API.XML()) 'Dim node = (doc.SelectSingleNode("//input[@number='10']/@key").Value) Dim node = (doc.SelectSingleNode("//preview").Value) Console.writeline(node )
I will like know the number of the source that it is in preview.
reggards
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Innertext instead of Value
Originally Posted by: doggy  Innertext instead of Value thank you. Global vars? it is not posible. 1.- If I have 10 inputs and I want to have a button that sends prev or program, where I store the variable of the conditional 2.- A source type colour. It is posible getter and setter color reggards
No but the trick to use is to have a unused title and use that as a location to hold a variable or write/read them from a simple text file Quote:
reggards
check what is available in the vMix API XML , if not there then again no Also check all the available shortcuts as practically all of those are available as a function usable within a script
