isidto
#1 Posted : Monday, March 1, 2021 12:02:28 PM(UTC)
isidto
Spain
hello,
Why this not works.
Dim doc as new XmlDocument()
doc.LoadXml(API.XML())
'Dim node = (doc.SelectSingleNode("//input[@number='10']/@key").Value)
Dim node = (doc.SelectSingleNode("//preview").Value)
Console.writeline(node )
I will like know the number of the source that it is in preview.
reggards
#2 Posted : Monday, March 1, 2021 3:11:14 PM(UTC)
Innertext instead of Value
isidto on 3/2/2021(UTC)
isidto
#3 Posted : Monday, March 1, 2021 5:43:08 PM(UTC)
isidto
Spain
thank you.
Global vars? it is not posible.
1.- If I have 10 inputs and I want to have a button that sends prev or program, where I store the variable of the conditional
2.- A source type colour. It is posible getter and setter color
reggards
#4 Posted : Monday, March 1, 2021 7:53:58 PM(UTC)
No but the trick to use is to have a unused title and use that as a location to hold a variable or write/read them from a simple text file
reggards
check what is available in the vMix API XML , if not there then again no
Also check all the available shortcuts as practically all of those are available as a function usable within a script
