3rd Party Software and Development
vMix Virtual Control Surface 3.0 iPad app [Now Available!]
Joined: 12/14/2018(UTC) Posts: 160   Location: Clermont-Ferrand Thanks: 35 times Was thanked: 9 time(s) in 8 post(s)
Originally Posted by: grapeguy  Is this app still available? Doesn't seem to show up in apple search.
On iPhone or on iPad ?
I was saying the same thing....never got the latest version downloaded, so I just looked for something else, and Panel Builder is the BEST so far...you design and layout your buttons to you taste, and there are a few examples you can download and modify ....it is the only control surface i a using for now...UTC is great, but lack the GUI of Panel Builder....wish the author would make a GUI somewhat like Panel Builder...
Hi, I'm very interested in your iPad app and going to buy it. But when I push the link to appstore, I get information that "This app is currently not available in your country or region". I'm from Tashkent, Uzbekistan. I really need your app. Dear friend, could you check it and let me know.
Hi, I'm Giovanni and I live in Italy. I need the app for an ipad, in my appstore is not found, and clicking on the link tells me that in my country this app is not available, how can I do to get it? thank you very much.
Joined: 4/23/2020(UTC) Posts: 8   Location: Maresme Thanks: 5 times
First, congratulations for great app. I work for 25 years about switcher and the last year i found Vmix. Powerful. And i pay for app, and test. Is great. More functional. I think a few ideas about more keys, but in general is good. But i found a bug, think. I’m not sure. When i put dsk1-2-3-4 on, i can’t view the tally of dsk ! Is very important see the tally because i work with a multiview and ipad app, and i need to see the tallys of dsk. Thanks.
I bought this app when it came out some years ago...it works great, but I was trying to download ver 2 when that came out, and never got it downloaded....the link did not work, and now it is the same...i can not get this app downloaded...the ver 2 was free for those who had ver 1 , and I never got it....I do not know why I can not get it download.....
Hi Seth,
Looking to use this App, but a few questions;
-For cloud workflows, Windows Server over W10 is easier to use on some platforms. Do you have any workaround for the HOME network requirement, which isn't an option on Server2019? I've set it to private which 'should' be the same. Any ideas? -Is this app compatible with iPhones? -Plus +1 to the Android version! -Can i run 2 iPads at the same time, 1 for switching and 1 for audio mixing?
Thanks, Simon
Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
We are getting ready to launch version 4.0 of the vMix Virtual Control Surface in the App Store for iPad! Here are some screen shots of the app. This should be released this month. Stay tuned! New Features: Video Tab: -New button graphics -Record button will display the length of the video recording in vMix -Streaming Button will have the ability to stop/start streaming individually for streams 1-3 -A label will appear above the stream button indicating what live streams are active Audio Tab: -Redesigned audio tab -Added stereo metering -Added Start/Stop/Replay icon added for audio inputs that are connected to video/audio files. -Added progress indicator for clips with any duration. When the clip reaches 10 seconds from the end, it will turn red -Added display of all audio buses when in use -Added support for custom audio bus label now included in v24 of vMix -Added ability to turn on/off audio assignments to all buses -Added feature of removing blank spaces where inputs that had no audio used to be. Removes any blank spaces between faders Config Tab: -Added input configuration tab! -Configurations are automatically saved on the iPad and are connected with the name of the vMix preset file you are using -Assign what video/audio inputs are visible in the video switcher and audio switcher -Assign what audio buses each input are assigned to  Simulator Screen Shot - iPad (8th generation) - 2021-01-08 at 09.36.51.png (469kb) downloaded 4 time(s). Simulator Screen Shot - iPad (8th generation) - 2021-01-08 at 09.24.02.png (579kb) downloaded 9 time(s). Simulator Screen Shot - iPad (8th generation) - 2021-01-08 at 10.03.01.png (1,568kb) downloaded 8 time(s). Simulator Screen Shot - iPad (8th generation) - 2021-01-08 at 10.04.12.png (1,626kb) downloaded 3 time(s).
 4 users thanked thecloudmediagroup for this useful post.
I have the very first version of this app, but was never able to get any of the other versions downloaded....so I gave up on trying......maybe, I would get this version downloaded when it is launched....
Originally Posted by: Joeboe  I have the very first version of this app, but was never able to get any of the other versions downloaded....so I gave up on trying......maybe, I would get this version downloaded when it is launched.... Shoot me an email at Seth@thecloudmediagroup.com. We'll get you hooked up.
Joined: 2/14/2019(UTC) Posts: 11  Location: Texas Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Got a production this Thursday that this would be perfect for. So uh....fingers crossed!
Joined: 5/28/2020(UTC) Posts: 3  Location: HORSHAM Thanks: 1 times
I’m in the UK and when I click on the link it tells me this app is not available in my region. Is this app available in the uk.
Version 3 is not available in the app store anymore. Have you pulled it or is this only available via private channels? Also is there a cost associated with this app?
Joined: 9/21/2020(UTC) Posts: 12  Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
thecloudmediagroup is the app running on the latest ipad update?
Any update on when V4 will be available?
Update to V4 is available. Looks great and love the new features. *Only issue I have so far is that every 10seconds the surface loses the buttons(keys go blank,then return)
 1 user thanked BRebels for this useful post.
Still experiencing the "Keys Drop".
