What would be a good way to create a players killed off overlay
Joined: 11/14/2012(UTC) Posts: 10 Location: Los Angeles
I have the following setup. Input is composed of a Multiview that has cam and graphics on the input, I build it color, then the Multiview layers, cam, graphics. I use a overlay 1 to display a scoreboard over the Multiview input. Now i would like to accomplish the following -> I have 4 players and each of them could die off in the round, I would like to trigger a big X over the Multiview per player which are in each corner of the screen, since i only have 3 overlays left what could i do? The X should be able to be triggered via a stream deck toggle button [img=https://postimg.cc/G81T3XVK]setup[/img]  setup.png (36kb) downloaded 0 time(s).https://i.postimg.cc/bJZxTMR7/setup.png
Assuming the player inputs are separate before put in the multiview ...
add a layer with the X on each of the player's input and use shortcut to turn these layers on/off ( or if you have four layers left in the multiview ...)
how would i trigger the layer in the multiview via a short cut?
Got it working in the shortcut menu, worked like a charm.
Thank you!
MultiviewOverlay shortcut: Toggle On/Off MultiView Overlay For Input At Index (starting from 1)
The helpfiles (other name for Manual) do have a Shortcut function reference list !
Thank you for the reply worked like a charm ;)
