shortcuts dont change picture in overlay, why?
System: Windows 8 Vmix version 11.0.0.66
I’m trying to make 2 shortcuts to inset nametag images, but It don’t change the photo when I press the shortcuts.
Construct the bug: The first one is on key NumPad 1, function OverlayInput1, Duration 100, the input is a photo input with 20 pictures, on the first shortcut I course picture 19.jpg and one the second shortcut named NumPad 2 I course picture 2.jpg. See the picture documentation!
Result: When I press NumPad1 or NumPad2 the current image is shown? The picture won’t change to eider 19.jpg or 2.jpg! I rely hope you can help me, course I am building an app the can change images in a photo input and it says on you homepage that what is possible in the shortcut is also possible in the API Correct me if I am wrong. Thanks.
Joined: 1/13/2010(UTC) Views messages in topic : 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
The function OverlayInput1 only turns on the overlay, it does not change pictures. To do this you will need to set the function to SetIndex. Then create a second shortcut for OverlayInput1. Then when that second shortcut is complete go to the Adanced tab of the first shortcut and add it to the list.
Martin vMix
Great thanks;) But i cant find the function setIndex only selectIndex, and the selectIndex function gives me an error (KeyDown.ES)?
Best regards Poul
Yes, sorry about that the function is SelectIndex and the Value box is where you enter the number of the photo from 1 to count.
The dropdown box showing pictures to select from only works with transition functions such as Cut and Fade and not for Overlay functions etc.
Martin vMix
