Gozzi.dk
#1 Posted : Tuesday, April 8, 2014 5:41:06 AM(UTC)
Gozzi.dk
System:
Windows 8
Vmix version 11.0.0.66
I’m trying to make 2 shortcuts to inset nametag images, but It don’t change the photo when I press the shortcuts.
Construct the bug:
The first one is on key NumPad 1, function OverlayInput1, Duration 100, the input is a photo input with 20 pictures, on the first shortcut I course picture 19.jpg and one the second shortcut named NumPad 2 I course picture 2.jpg. See the picture documentation!
Result:
When I press NumPad1 or NumPad2 the current image is shown? The picture won’t change to eider 19.jpg or 2.jpg!
I rely hope you can help me, course I am building an app the can change images in a photo input and it says on you homepage that what is possible in the shortcut is also possible in the API Correct me if I am wrong.
Thanks.
#2 Posted : Tuesday, April 8, 2014 8:37:15 AM(UTC)
The function OverlayInput1 only turns on the overlay, it does not change pictures.
To do this you will need to set the function to SetIndex. Then create a second shortcut for OverlayInput1.
Then when that second shortcut is complete go to the Adanced tab of the first shortcut and add it to the list.
Gozzi.dk
#3 Posted : Tuesday, April 8, 2014 9:04:36 AM(UTC)
Gozzi.dk
Great thanks;)
But i cant find the function setIndex only selectIndex, and the selectIndex function gives me an error (KeyDown.ES)?
Best regards Poul
#4 Posted : Wednesday, April 9, 2014 1:20:38 AM(UTC)
Yes, sorry about that the function is SelectIndex and the Value box is where you enter
the number of the photo from 1 to count.
The dropdown box showing pictures to select from only works with transition functions
such as Cut and Fade and not for Overlay functions etc.
Gozzi.dk on 4/9/2014(UTC)
