the first crash! Please help! soft or hardware ?
Rank:: Newbie
I still using HP Z820 workstation.
Faulting application name: vMix64.exe, version: 23.0.0.54, time stamp: 0x5eb3c50d Faulting module name: mscorwks.dll, version: 2.0.50727.9151, time stamp: 0x5e75a06b Exception code: 0xc0000005 Fault offset: 0x00000000002b1285 Faulting process id: 0x%9 Faulting application start time: 0x%10 Faulting application path: %11 Faulting module path: %12 Report Id: %13 Faulting package full name: %14 Faulting package-relative application ID: %15
Please Help to find out what is the worng?
Thanks!
Rank:: Newbie
.NET Runtime version 2.0.50727.9151 - Fatal Execution Engine Error (00007FFC94BB6D4E) (80131506)
Rank:: Newbie
EX FPS:60 RENDER TIME:7MS GPU MEM 100% CPU VMIX 21% TOTAL 22%
GRAPHICS CARD: GEFORCE GTX 980
I using 3 cameras in studio and 6 calls from internet.
Joined: 8/24/2017(UTC) Posts: 21 Location: Madrid, Spain
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
Years ago I had a similar error on two similar computers. I tried to fix it by updating .net v2.0.50727 and replacing the mscorwks.dll file with a new one but it didn't work. A reinstallation of Windows 10 was done on both computers without installing that version of .net and they work without problems.
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Best to drop us an email so we can investigate further. All our systems are running .NET 2.0.50727.9151 without issue, so this may be caused by something else.
Martin vMix
Hi, We have just had this same fault today Error 1 .NET Runtime version 2.0.50727.9151 - Fatal Execution Engine Error (00007FFC859B6D4E) (80131506)
Error 2 Faulting application name: vMix64.exe, version: 23.0.0.68, time stamp: 0x601394a5 Faulting module name: mscorwks.dll, version: 2.0.50727.9151, time stamp: 0x5e75a06b Exception code: 0xc0000005 Fault offset: 0x00000000001c49b2 Faulting process ID: 0x%9 Faulting application start time: 0x%10 Faulting application path: %11 Faulting module path: %12 Report ID: %13 Faulting package full name: %14 Faulting package-relative application ID: %15
Was there a solution?
In all the cases we have seen it is caused by faulty hardware or a corrupt windows installation. If a reinstall of Windows does not solve the problem you will need to look at the hardware. Could me memory, motherboard, cpu, graphics card or power supply.
In some cases updating the bios on the motherboard may help.
Check the Windows system and application event logs for other failing apps or driver errors.
Martin vMix
hello, today we had the same error and you have answered me from support.
The problem is that we cannot make a diagnosis to know what hardware has failed?
Is there a tool that can give you a clue that something is wrong? especially to prevent the problem from happening in a live show.
Hello! I’ve had this issue happen on two separate systems in the past, within the last 6 months though!
One was intel based and another AMD based but they had the same error, it was unpredictable!
I saw somewhere else on the forums about it possibly been related to web control but I’m not sure, I’ve had my web controller disabled and haven’t had any crashes since but it is very random so I don’t know.
Seems very odd that both machines which I’ve had less than 12 months would both have hardware issues or windows installs, they were both fresh installs!
Would love to get any further detail on this matter, I’m always on edge incase of a sudden CTD.
